(SOLVED) Simple circuit does not work in LTspice
Danko
Joined Nov 22, 2017
2,233
Сircuit below oscillates in reality, but not oscillates in LTspice simulation.
How to simulate such kind of circuits in LTspice?
Oscillogram of real circuit:
LTspice simulation:
panic mode
Joined Oct 10, 2011
5,210
what you have on board and what you have in simulation are two different things.
on board you have emitter of PNP transistor connected to +
but in simulation, emitter and collector are swapped on both transistors.
btw. not everything works in simulation.
here is a simple astable multivibrator that definitely works in real life but fails in LTSpice
which is why LTSpice includes its own 'educational' version...
base resistors are purposely mismatched to help start oscillations.
increasing their value some 10x does make the this circuit work as well.
38,762
That's a common misconception.
Don't panic. ;)
It's not a simulation failure, it's a failure to communicate.
Many who use LTspice don't realize that it normally calculates the circuit DC operating point before the transient analysis.
In this case the circuit can settle into a quasi-stable DC state since there is no natural noise or asymmetries in the circuit.
If you omit the initial DC calculation by using either the startup or UIC option in the transient analysis, the oscillation occurs nicely, even if nothing is mismatched (below):
Danko
Joined Nov 22, 2017
2,233
Don't see how.
The simulated transistors both have reverse polarity voltage applied to them.
Post your real circuit schematic.
For wide range of possible R1 value changes, without latching,
β of Q1, Q2 should be as close to 1 as possible.
Therefore Q1 and Q2 used in reverse mode (β=2-3).
See how oscillator works with transistors in normal mode -
one infinite pulse (latching):
See:
Danko
Joined Nov 22, 2017
2,233
Reverse mode is with the base and emitter interchanged.
"Reverse-active (or inverse-active or inverted)
By reversing the biasing conditions of the forward-active region,
a bipolar transistor goes into reverse-active mode.
In this mode, the emitter and collector regions switch roles."
https://en.wikipedia.org/wiki/Bipolar_junction_transistor#:~:text=Reverse-active (or inverse-,and collector regions switch roles.
You had the NPN and PNP reversed.
Every transistor is reversed (collector and emitter interchanged).
ADDED:
Nobody answer my question - how to simulate this particular circuit?
Seems reversed mode not detailed in LTspice BJT models...
panic mode
Joined Oct 10, 2011
5,210
same here...
starting with output low, C1 is charging and Q1 base potential is increasing.
at some point Q1 and Q2 turn on so the output (red) is high.
but capacitor voltage cannot change instantaneously so this rise means voltage increase on Q1 base as well.
this only helps drive both transistors into same direction which is steady state.
don't see how they will ever turn off... maybe something not obvious is taking place (tunneling?)
tiwag
Joined Jun 17, 2010
LTspice simulation:
Some basic understanding in electronics would help.
You need a bigger RLoad resistor in order to get enough basis voltage for Q2 to get into conduction.
Thats it, then it works fine
HTH Tiwag
tiwag
Joined Jun 17, 2010
HTH Tiwag
Here is an optimized version which works more robust
Danko
Joined Nov 22, 2017
2,233
Reverse β is set: BR=20 for Q1 and Q2.
Result: good coincidence.
LTspice diagram:
Oscillogram from real circuit:
k1ng 1337
Joined Sep 11, 2020
1,038
We must subscribe to the requirements of Nature or it will not do what we want it to do!
Julius Sumner Miller
So I ask, did the circuit NOT work or did you just fail to understand it? :p
