Isn't that what you would expect? NC is not connected to anything.Yes the relay gives a click sound on 12 v supply I have cross check led, there is no fault with led. I get 0v between NC and common
Yes... you expected differently? NC is a closed switch. A wire until it’s opened. Voltage across a wire is 0V.Yes the relay gives a click sound on 12 v supply I have cross check led, there is no fault with led. I get 0v between NC and common
