[SOLVED] DS1307 Datasheet
MTech1
Joined Feb 15, 2023
181
I've gone through the DS1307 datasheet multiple times, trying to determine which clock edge it uses for data reception from the master and data transmission to the master. However, I couldn't find this specific information in the datasheet. The only relevant diagram I found was Figure 8 on page 11, but it didn't provide a clear information. As many mentioned before on a forum, data can often be transferred or received on either the rising edge or falling edge of the clock, and I believe the configuration of the clock edge is determined by the slave device. Therefore, we should be able to configure the master's clock accordingly
BobTPH
Joined Jun 5, 2013
11,662
The way I read it, it does not matter. The data must be stable for the entire high period of the clock, so the results will be the same whether the data is latched on the rising edge or the trailing edge, or anywhere in between.
MTech1
Joined Feb 15, 2023
181
Do you agree that in the I2C protocol, data is typically transferred or received at the clock edge, not for the duration of the clock high or low?
During the low period of the clock, data may change, and during the high period of the clock, data should remain stable.
If I ask to you on which clock edge data would transfer and receive in I2C, how do you determined on either the rising or falling edge of the clock what would your reply on this matter?
I'm interested in understanding the selection process of clock edge for i2C based application development. As an application developer, what factors should we consider when choosing a clock edge , and why perticular should select? I'd appreciate your help on this matter
BobTPH
Joined Jun 5, 2013
11,662
I have no experience with I2C, so I cannot answer your question.
Can you tell me why you are concerned with which edge latched the data on the DS1307 you are talking about? Assuming you do not violate the requirement that the data is unchanged during the entire high period, how could you even tell? How would it change what you did to interface to it?
BobTPH
Joined Jun 5, 2013
11,662
Apparently 2-wire is an attempt to avoid the trademark of I2C.
For triggering, I found this.
I2C is a Level Triggering. A device that sends data onto the bus is defined as transmitter, and a device receiving data is defined as receiver. The bus has to be controlled by a master device which generates the Start and Stop conditions, while the Some devices like LCD, EEPROM, RTC are works as slave.
35,219
The information is on Figure 8 of the datasheet. The data setup and hold times are shown and specified on page 10.
MTech1
Joined Feb 15, 2023
181
I came across link on internet now forgotten link suggesting that the master transfers data on the falling edge, and the slave receives data on the rising edge. This prompted me to wonder under what conditions the master could transfer data on the rising edge and when the slave could receive data on the falling edge
Ian0
Joined Aug 7, 2020
13,291
That sounds much more like a description of SPI than it does of I2C
MTech1
Joined Feb 15, 2023
181
Do you mean that we don't specify clock edges in I2C, as we do in the SPI protocol? In I2C, the sender should set the logic level (high or low) on the SDA line while the clock signal is low, and the receiver should read the status of SDA while the clock signal is high.
Ian0
Joined Aug 7, 2020
13,291
No. It is specified in the standard. There are no options to change anything.
MTech1
Joined Feb 15, 2023
181
Thank you for clarifying. I now understand that in the I2C protocol, we cannot change the timing. Specifically, the sender sets the logic level (high or low) on the SDA line while the clock signal is low, and the receiver reads the status of SDA while the clock signal is high.
BobTPH
Joined Jun 5, 2013
11,662
Yes, that is called level triggering as opposed to edge triggering.
