[solved] capacitor values questions
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Hello.
I have some questions about capacitor values.
For instance, I have here some ceramic capacitors with value of 103. I know this means 10 x 10³pF = 10nF. But why is the value underlined? Is there any specific meaning?
Another question is that some capacitors have this small black marking on the top. What is the meaning of that marking?
And lastly these ones. What is the meaning of those 2 colour marks?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
I also wanted to understand something else.
I was testing a few capacitors here, to try to see their charging time constant and confirm on the scope.
For instance, I am using a 1MΩ resistor and this 1P5 (1.5pF) capacitor and I was expecting τ=1.5pF x 1MΩ = 1.5us. Then, after 5τ, I would expect the capacitor to be charged up to 99.3% of Vmax (which is 7V in my case).
So, I would expect 5τ = 7.5us to be at 7V x 0.993 = 6.993V.
However, this is what my scope shows:
Max voltage is way less than the expected 6.993V (aroun 6.16V) and the charging time is like exceeding by a factor of 10. It should be aroun 7.5us and I think I can assume the cursors are more or less at the initial point and at the max voltage.
AlbertHall
Joined Jun 4, 2014
12,653
Apart from the resistor and the capacitor you also have an oscilloscope connected. The 'scope does not have an infinite input resistance so it will affect the readings.
Tonyr1084
Joined Sep 24, 2015
9,744
I'm no capacitor expert, but I'm wondering if maybe some of the deviations may be due to ESR (Equivalent Series Resistance), or possibly some sort of leakage in the cap. They DO leak some current. Which is why they tend to lose their charge over long periods of time. Some of that may be coming into play.
drjohsmith
Joined Dec 13, 2021
1,650
Also
real capacitors have terrible tolerances,
Ya’akov
Joined Jan 27, 2019
10,300
A combination of all the foregoing: the practical impedance of the scope probe, the possible contribution of ESR, and the fact that caps are pretty crappy when it comes to values could easily cause deviations in the expected result. A simulation that can eliminate all of these should provide the expected results.
Measuring the actual value of the cap and resistor might clear things up, if you have a sufficiently accurate LCR meter.
35,181
Here is the reason why your test and analysis is flawed.
After 5 time constants, the voltage reaches approx. 99% of the charging voltage.
This measurement reveals the effect of Rprobe on the measurement and nothing about C and Cprobe.
With a probe resistance 10 times the value of the resistance under test, one would expect to see about 10% error in voltage measurements.
(You can verify this by examining your results. 10% of 7V is 0.7V. Is your measurement off by 0.7V?)
In order to measure the RC value, use the 1 time constant measurement, i.e. the time taken for the voltage to reach 63% of the charging voltage.
The addition of both Rprobe and Cprobe into the circuit will alter your analysis significantly.
Audioguru again
Joined Oct 21, 2019
6,826
1M ohms and 1.5pF have a time constant of 1.5us and a -3dB cutoff frequency of 106.7kHz.
Why not 1k ohms and 1.5nF if the signal source resistance is much less than the 1k ohms?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Ok, I understand now why.
Anyway, I step into this because I was trying to use one of those component testers that one can buy from Aliexpress or so, and only one capacitor was detected by this testing device. So, to try to check if the other capacitors were OK and to make sure about their stated values, I tried to go for the charging times to see if they would match the values they had written on them.
@Yaakov my meter can only measure from 50nF and up. It's a Brymen BM869s.
From the manual:
@MrChips, as you can see from my scope screenshot, Vpp is 6.48V and the voltage at cursor is 6.16V, so, yeah, maybe that's the case, about the 10% error.
Ok, so this said, I think I can call it "solved".
Thanks to everyone.
Psy
35,181
Also it would be extremely difficult to measure 1pF without special equipment and effort.
Two pieces of wire about 1 inch long close to each other is about 1-5pF (I'm guessing).
Hence our limit is about 10pF.
A C meter with a range of 0-1000pf would have an error of about 10-100pF (i.e. about 1-10% error).
