[SOLVED] Capacitor to extend LED blink length
mike__MecE
Joined Feb 20, 2022
92
The LED receives a 10ms pulse (48VDC) and I would like to use a capacitor to extend the length it is illuminated.
Why is the simulation is not responding to the capacitor, regardless of the capacitance. Is there an issue with the schematic? Thanks
AnalogKid
Joined Aug 1, 2013
12,280
Yes.
When V1 goes to 0 V at the end of the pulse, it still is a zero-ohm impedance. It discharges C1 just as fast as it charged it. A simple solution is in post #2.
Note that I am *not* an LTS wiz; others around here can confirm this or not.
ak
35,191
If you expected to see the blink duration dependent on the capacitor value and the load current, remove the load (LED and series resistor) and run the simulation showing just the capacitor voltage.
Tonyr1084
Joined Sep 24, 2015
9,744
Insert diode in series with the V1, anode to V1. 1N5401 or similar
What these two learned experts are saying is this:
In this configuration C1 will charge with the pulsed voltage. When the pulse is gone C1 will continue to illuminate LED1 until its voltage drops below some threshold and will drop at some rate. If you're flashing the LED faster than C1 discharges the LED will never go out.
Tonyr1084
Joined Sep 24, 2015
9,744
Here's a short YT video I made some time ago answering another AAC user's question. It's not the same circuit, but it demonstrates how a cap can charge fast, then, depending on the current draw, how long the LED will remain illuminated. In the video you can see the diminishing light.
mike__MecE
Joined Feb 20, 2022
92
Yes.
ak
Thank you! I didn't realize the capacitor would discharge through the voltage source.
mike__MecE
Joined Feb 20, 2022
92
The solution was to add a diode to stop the capacitor from discharging via the voltage source. Thanks for your input!
mike__MecE
Joined Feb 20, 2022
92
Thank you, it's working. I understand the need for the diode in the simulation.
mike__MecE
Joined Feb 20, 2022
92
That's great, thanks! My circuit uses a pulse from a MOSFET which is protected from reverse current so I did not immediately think of the need for the diode as others suggested for the simulation.
