[Solved] Avoid soldering test chip into circuit? Spring contacts or something else anyone?
ballsystemlord
Joined Nov 19, 2018
253
When designing a circuit, I found myself with a few choices of surface mount ICs, all four of which looked like good choices. They each have different specs, and I just wasn't sure which would work better for my application. I ordered each for testing purposes.
I'd like to solder each to it's own test board, and then be able to insert/remove the test boards from the rest of the circuit at will. Needless to say, having to solder and then remove each chip and/or each board would be a pain.
Are there any spring contacts or other solderless methods (non-breadboard) that would work for my application?
Edit: Many good answers below.
