[SOLVED] 3-phase 400VAC interfering Arduino operation
LowQCab
Joined Nov 6, 2012
5,102
You may not have RFI as a problem .......
Other possibilities .........
When a big powerful 3-Phase-Motor Starts,
it puts out a massive magnetic Pulse from the heavy start-up Current Spike.
This is enough to temporarily turn any metallic-objects near by into temporary Magnets.
It may also cause Electrical Currents to temporarily flow in large heavy metal structures,
enough to actually cause arcing or galvanic corrosion weirdness.
Running your Sensor-Wiring in Metallic Conduit may be the solution.
abuhafss
Joined Aug 17, 2010
318
I have already mentioned, the sensor wires are shielded.
Secondly, I have also pointed out in post #20, that even if the sensor wires are disconnected still the opto coupler gets ON when the pedal is pressed or released.
LowQCab
Joined Nov 6, 2012
5,102
"Shielded" is not the same as Shielded plus being run inside of a Steel, EMT-Electrical-Conduit-Pipe.
Not even comparable.
Some Industrial installations require EMT-Conduit for Low-Voltage-Controls,
even when the NEC-Code says it's "Class-II" Wiring, which can be run exposed.
abuhafss
Joined Aug 17, 2010
318
Okay, got it.
But, what about the pulses received at the opto coupler, even when all the three wires of the sensor are disconnected?
abuhafss
Joined Aug 17, 2010
318
How long is the pulse you are expecting from the proximity sensor? And how long are the spurious pulses?
Yes, I was also thinking on the same track.
The length of the pulse from the proximity can be controlled from 100-200 ms whereas, the false pulses appears to be 50ms or less.
mbrooke
Joined May 31, 2021
The problem is most likely that you are not showing us your ground wiring. I suspect that the sensor "ground" and the Nano "ground" are actually quite far apart electrically and you are getting significant ground "bounce" in the sensor when the press actuates. You may need a well shielded ground running from the Nano to the optocoupler and you should disconnect the sensor ground from the optocoupler output. That way the press noise on the sensor ground will not get to the Nano. The shielding of the ground from the Nano is to protect it from picking inductive noise. Ground symbols are the worst thing ever invented there is no such thing as ground. It is just another power supply and so can have voltage fluctuations, pickup noise, and needs filtering / isolation too.
Ian0
Joined Aug 7, 2020
13,267
The sensor is installed separately on the press, quite far from the console box containing the contactors.
The pedal is not connected to Nano.
I have mentioned earlier, the press operation is controlled separately by 3-Phase 400VAC supply.
The Nano just controls the Stepper Motor when the sensor gets ON.
In the present scenario, when the pedal activates the contactor to run the press, the opto coupler gets a false pulse when the pedal is pressed (when the contactor activates) and when the pedal is released (when the contactor deactives).
Interestingly, even if the sensor wires are removed from the circuit, still the opto coupler gets those false pulses.
Is your opto-isolator near the sensor, or near the nano. The output of the opto is much more sensitive to interference than the input.
MaxHeadRoom
Joined Jul 18, 2013
30,806
One important thing, I have noticed is that the sparking contactor interferes only when the common wire of the push buttons is connected to the 5V line. When the wire is disconnected (buttons disabled) there is no disturbance.
One thing I have experienced with contactors is the coil is usually the culprit as the source of 'noise', if of the AC variety.
A R/C snubber across the coil usually corrects it.
abuhafss
Joined Aug 17, 2010
318
First of all, welcome to AAC !!!
The sensor is installed on the press but the wires are connected to the control circuit.
abuhafss
Joined Aug 17, 2010
318
It near the Nano.
What value of the pull-up resistor would be suitable at the output of the opto?
MaxHeadRoom
Joined Jul 18, 2013
30,806
Earth Ground is just a reference point and not intended to be a conductor.
The problem is not with the symbols, but with N.A. terminology, the term "ground" is used for a supply common whether it is at earth GND potential or not.
In my many decades of industrial wiring using the proper earth GND techniques and taking all supply commons to a earth star point has eliminated any spurious problems of random noise.
Ian0
Joined Aug 7, 2020
13,267
It near the Nano.
That's the best place for it.
It's difficult to give absolute answers to problems like this, but I'll give you a "worth a try" answer.
Can you route the 24V power supply to the sensor so that it(especially the -ve) doesn't go near the nano? Then bring the opto wires back as twisted pair. Make sure that there is NO connection between the two sides of the opto at the opto.
For good measure an inverse parallel diode across the opto diode, and also a 1k resistor, so that the first mA bypasses the opto, and it looks sort-of balanced to any interfering signal.
10k will require about 500uA through the opto to get a signal at the other side that reads as a logic zero.
Reducing it too much will reduce the logic noise margin.
I'd leave it alone until you can get investigate further and probably capture some waveforms.
Before you do, put the RC snubber across the contactor coil as @MaxHeadRoom suggested.
abuhafss
Joined Aug 17, 2010
318
The conclusions from the discussions so far are:
a) Add RC snubber across the contactor coil. (I will do it).
b) The sensor wires to be shielded, particularly in metallic conduit. I think the original wires connected with the sensor are not shielded. However, the additional length attached is shielded. (I will do it).
c) The 24V and 5V should have separate 0V line, though I was using a 24V SMPS and a buck converter to get 5V. (I will use a totally separate 24V SMPS only for opto. Should I enclose the new 24V supply in the same metallic cabinet?)
d) Connect an inverse diode across the opto's diode. (I will use a 1N4007).
e) Should I connect a 4.7K pull-up to the output of the sensor?
f) Should I connect a 4.7K pull-up to the output of the opto?
Next, just for the sake of learning, would someone help me understand:
i) Why the opto gets the false pulse, even when the sensor wires are disconnected?
ii) Why the opto gets the false pulse only if the common of the 2 push buttons are connected to 5V. I have tried removing the buttons from the press but nothing changed.
MaxHeadRoom
Joined Jul 18, 2013
30,806
I would say there is some power common that is not referenced to earth GND.
A decent schematic of the whole operation would be nice.
In fact, that is the normal course of action when implementing a system such as described.
abuhafss
Joined Aug 17, 2010
318
The issue has been resolved.
a) RC snubber did some job but not completely.
b) The sensor wires did not caused those interference.
c) The secondary 24V supply was not required.
d) Don't know if 1N4007 did anything good.
e) 4.7k pull-up at the output of the sensor did not improved anything.
The main culprit was the coil of the pneumatic valve which is activated by the pedal and the long wires of the push buttons.
THANK YOU EVERYONE WHO PARTICIPATED IN THIS DISCUSSION, FOR THEIR VALUABLE INPUT.
LowQCab
Joined Nov 6, 2012
5,102
If using an Arduino or any microprocessor, there should always be snubbers across all AC inductive devices and Diode rectifier across any DC inductive devices.
You have to be careful making that into a blanket statement,
there are many situations where Snubbers/Diodes can "slow-down" mechanical action
to the point of creating erratic, or severely delayed behavior.
I've found this mostly with DC devices, but generally I agree with you otherwise.
