Solve: Y(A,B,C) = (A+B+C) . (A+B+C`) . (A+B`+C`) with complete steps and explanations.
OKSolve: Y(A,B,C) = (A+B+C) . (A+B+C`) . (A+B`+C`) with complete steps and explanations.
you can solve it for particular A , B and C valuesSolve ... with complete steps and explanations.
Hi MrChip, Actually I'm very new here, I didn't know much about the rules, I'm sorry for my mistake. I've a Bachelor's Engineering Degree in Electronics and Communication and worked as an IP/SoC Design Engineer for the past 4 years.That is not how AAC Homework Help works.
You show your best efforts at your coursework and we will guide you after that.
If you don't mind post it here.OK
Solved already according to your instructions, Sir.
What is next?
Hi, I've attached the full step minimisation. If you have any other method to solve this please do post. Thank You!So, Show us the steps and final result. How did you manipulate the equation?
I want this expression in max minimised form, in a way how you solve this. Thanks for the comment!you can solve it for particular A , B and C values
you can write a truth table for all possible combinations of the A , B , C values
? what exactly you should do
I use a two-step method.If you have any other method to solve this please do post.
I am unable solve the error 10500. | FPGAs (Field Programmable Gate Array) | 1 | ||
Solve exercise 2 in this question paper | Homework Help | 5 | ||
S | need help to solve this boolean expression | Homework Help | 5 | |
J | How to solve these boolean equations? | Homework Help | 9 | |
M | Please please solve this boolean expression | Homework Help | 3 |
by Jerry Twomey
