And when the TS progresses to TQFP devices, how would you deal with them? DRC default settings in many programs are so 1990.The spacing between pins on the transistors is almost nothing.
You could edit the foot print and spread the leads a little. Or you could make the copper around the holes smaller.
I did not modify. Actually the NETLIST had already chosen the footprint for Q1-2 by itself.Did you modify the TO-92_inline package? The one from the library works fine for me with default DRM settings.
If you go with Ron's suggestion you can use the TO-92_inline_wide which has double the pitch. I always use the wide package because it makes DIY etching easier.
Exactly. Now see if you can untangle all of them.oh its called airwires. They are moving around when I move the footprints.
That is how I run a few tests cases before manually routing. Autorouting will be a lot quicker at finding issues that can be solved by rotating or moving a component.I actually think I did a good job untangeling them autorouter were able to route them on two layers.
by Robert Keim
