Hello, I have the same problem. Where do you change that in KiCad? I am using an AD8003 and the pads are 0.25 wide and the distance between pads are 0.5.Hi,
I am running Design Rules Check in KiCad/PBCNEW and I am prompted this error:
Q1-2 are transistors.
What should I do to solve this matter?
Thank you
Moderator edit: Move to a new thread from this one:
https://forum.allaboutcircuits.com/threads/solution-to-pad-too-close-to-pad.171411/
