Hello All,
New to the forum.
I have an air compressor from Silentaire.
http://www.silentaire.com/silentaire/index.asp
I use the compressor for my air bearing tone arm. However, the compressor makes popping noise through my audio system. I plugged the compressor in different power outlet but the main power is same as the audio system. There is no other options for me to use different power main.
The popping noise may come from the pressure switch of air compressor, or from the motor of air compressor. I have tried solid state relay to replace the pressure switch, it doesn’t work. I also used two Red Lion RC snubbers to cross the switch and the motor. Nothing works.
Can anyone suggest a solution for me?
Thank you in advance!
Jim
New to the forum.
Jim
