Solid state SPDT switch with mosfets
Tajerek
Joined Jul 14, 2017
7
Hi Guys,
I need some help to design the SPDT switching between capacitor and inductor in a solid state way. I am now using a mechanical relay which is not efficient especially when frequency is increased. In fact I want to control the switching frequency from a control circuit (like an arduino or 555 timer...etc) for tuning to resonance but I need to know how to make this SPDT solid state switch with mosfets.
desired voltage and current are 500V 40A
If such SPDT solid state relay exists in the market it would be nice also.
-live wire-
Joined Dec 22, 2017
959
Look for IGBTs. They are best suited for high voltage switching. It is also recommended that optocouplers are used for better isolation if you have low voltage parts you need to protect.
-live wire-
Joined Dec 22, 2017
959
Here is a good video on the subject of IGBTs. It talks about many of the things you need to know, from basic wiring to power consumption. For NPN IGBTs, you connect the grounds together at the collector. Then apply your signal to the gate. It will connect your load to ground when powered. But there are certain requirements to have it act like a closed mechanical relay. The video explains it well.
ebp
Joined Feb 8, 2018
2,332
If you directly connect a low-impedance voltage source to a capacitor the current will be limited only by the source impedance, switch resistance, wiring resistance, capacitor resistance and stray inductance. At 500 volts the instantaneous current could be hundreds to thousands of amperes.
Beyond that - if you are playing with voltages and currents of the magnitudes stated and asking how to do the switching, I will not offer any suggestions, as it is clear to me you don't know enough to go anywhere near such a circuit. This is orders of magnitude more dangerous than several things that are banned as topics at AAC.
AnalogKid
Joined Aug 1, 2013
12,128
20 kW is a lot, and 1 kV FETs do not have the ultra-low Rdson and fast switching frequencies of their lower-voltage cousins. What is your max switching frequency and (if not a 50% square wave) the minimum on or off pulse widths?
Between the Rdson and the transistor bandwidth limits, the devices will be dissipating some serious heat. At 99% overall efficiency (a very difficult number to achieve) it would be at least 200 W. Also, you probably will need multi-amp gate drivers.
ak
Danko
Joined Nov 22, 2017
2,169
POWEREX KD221K05 Dual Darlington Transistor Module 50A 1000V
This module contains 2 switches, exactly what you need.
But It is easy to obtain resonance and desired voltage with simple, low power circuit (see simulation below).
Average current from 12V power supply in this circuit is 25mA.
