Need a solid state SPDT relay IC
DickCappels
Joined Aug 21, 2008
10,662
Have you considered a lowly transistor? They can be cheap and reliable.
What is the nature of your load and the signal to drive your switch? If it is not reactive this could require a 10 cent solution.
ebeowulf17
Joined Aug 12, 2014
3,307
What sort of "output" are we talking about here? Is this just a simple logic (on/off) signal, or is it something analog like an audio source or the signal from a sensor of some sort?
stormBytes
Joined Jan 26, 2010
43
Thank you for the helpful suggestions. I've been completely distracted by other parts of the project. Have since settled on a different route so no further need for the part. Very much appreciate everyone's input!
