Will my solid state relay need a heat sink?
whitehaired novice
Joined Jul 15, 2017
289
I need to turn on and off a 1/3 HP 120 volt pump motor. I have a solid state relay which is rated at 40 amps 120 vac. Can I use this without a heat sink? It will turn the pump on for about 20 minutes at a time. The off time will always be more than an hour, usually several hours. Thanks for your help.
As a side note, I originally ordered a relay with a 5 volt coil with contacts rated at 12 amps at 120 vac. But when it came it was so small that I don't think it could possibly handle a 1/3 HP motor. (3/4 in x 1/2 inch x 3/8 inch)
wayneh
Joined Sep 9, 2010
18,173
I was all set to say yes. My car’s radiator fans are controlled by SSRs and they’re mounted to the frame to cool it.
But your pump should be drawing only 2 amps or so, and I would not expect a heat problem on an SSR rated so far above that.
