I am creating a new post, as I couldn't find the answer for my question. There is very similar post in the forum, but I think my case is slightly different, as I have a solenoid with higher resistance.
I have a very simple 12V circuit with a relay (controlled by 5V, very common relay) and solenoid. However, I would like to use some diode to reduce the arc effect when I break the circuit by relay.
The solenoid resistance is around 2 Ohm, which gives 6 amps current. The measured peak voltage during breaking circuit is up to 50V.
What diode should I use to reduce the arc effect? 1N4148 is usually used in this role, but it is up to 3A.
How can I calculate the current which will flow through the diode when I break the circuit?
