Solenoid electromagnet is getting hot instead of magnetic
eculver
Joined Jul 21, 2020
I am working on a project using magnetorheological fluid (MR Fluid).
Right now, I have a setup for testing the Mr fluid with two syringes connected by a small piece of ptfe tubing. I can lock the fluid when holding a neodymium magnet to side.
My goal is to replace that magnet with a solenoid magnet that the tube passes through so that I can lock the fluid at will. My problem lies with the magnet design.
I have tried using soft steel pipe that is a snug fit around my tubing with washers on both ends as a spool. I then use about a thousand turns of 24 gauge wire around said spool to create my magnet. Running it with 12 volts was drawing about 1.2 amps and not creating a strong enough field to lock the MR fluid, and when i tried turning the voltage up, it increased the amp draw but the magnetic proceeded to get very hot. I have also tried forgoing the pipe and wrapping the wire directly around the tubing with similar results. What can I do to make the magnet stronger, and stay cooler?
Details on materials
Ptfe tubing is 0.25" od
steel tubing is 0.5" od 0.25" wall
power is benchtop powersupply with 30v 5a max
Any advice is appreciated.
Irving
Joined Jan 30, 2016
5,195
Think about the direction of the magnetic field.
The magnet is polarised through its faces, so held to the tube the magnetic field passes through the fluid
The electromagnet produces a magnetic field along its axis, it passes along the soft iron core. There will be virtually no magnetic field inside that cylinder. A solenoid has a solid core.
38,951
But a solenoid core is hollow, and it's the magnetic field in the hollow that attracts the solenoid core.
eculver
Joined Jul 21, 2020
Thank you for the advice. due to limitations on space I can not fit a solenoid on the side. I dont know a lot about magnets, but would wrapping the wire through the length of the tube so that instead of seeing a densly packed slinky on the outside you would see a large number of parallel lines along the length of the tube achieve a similar effect?
BobTPH
Joined Jun 5, 2013
11,678
Two things:
The magnetic field will be proportional to the number of turns and the current. To get more field, more turns is a good thing.
Secondly, does the direction of the field make a difference? If you put the pole of your neodymium magnet facing the tube, that would be transverse to the flow, whereas a solenoid around the tube would be parallel to the flow.
Bob
Irving
Joined Jan 30, 2016
5,195
Yes, but the field in this instance with a soft iron core is all in the core, no in the space inside the core. Without the core, the air solenoid produced a much smaller field, and its in the wrong direction. Compared to that rare-earth magnet its probebly a few 100 time smaller.. An axial field won't lock the fluid AFAIK.
ElectricSpidey
Joined Dec 2, 2017
3,370
A simple test of this theory would be to turn the neo magnet 90 degrees and see if it stiffens the fluid.
Or place the electromagnet you already made perpendicular to the tube.
Irving
Joined Jan 30, 2016
5,195
Lets try some math.
1000t of 24awg for sake of argument 2" long = 50mm
dia 24AWG = 0.02", therefore 100t per layer, 10 layers
B = 4pi*10e-7 * turns/length * I = 4pi*10e-7 * 1000/.05 * 1.2 = 0.03Tesla
A rare-earth magnet ~ 1.4Tesla
QED
DNA Robotics
Joined Jun 13, 2014
671
In a solenoid, the magic happens in the inside gap.
The North & South poles are on opposite sides of the gap.
The magnetic field is created in the exterior armature and the gap is where it will magnetize your fluid.
Its late. Maybe someone can explain it better.
Irving
Joined Jan 30, 2016
5,195
If I knew the space available I could design you an electromagnet that would do the job, but we need more information.
