Soldering wires to pogo pins
DickCappels
Joined Aug 21, 2008
10,661
Simple answer: Get out your ruler, mark, then drill the necessary holes at the necessary spacing. If you don't need them mounted on a board, I would strip back a length of wire, solder it to the solder pin, and then slip then shrink a piece of heat-shrink over it for some mechanical support.
Lateralleap
Joined Mar 5, 2022
Thanks. That was my immediate approach but I thought there might be crimp sockets that could add more support
28,286
Some pogo pins do have sockets available, and I recommend that because soldered pogo pins with the solder in the wrong part are a rea challenge to remove the errant solder.
