Soldering problem.
Ya’akov
Joined Jan 27, 2019
10,278
I don't understand how mounting the switch on a PCB would help, I'm a complete novice but surely the switch terminals are still the same distance apart so how does it make them easier to solder??
The PCB would have traces on it that lead to where they would solder the connections. They would have pads suitable for hand soldering.
Ya’akov
Joined Jan 27, 2019
10,278
Not wishing to sound like a complete idiot but don't the terminals still need to be soldered to the PCB
There is a difference between soldering wires to the terminals on the switch and soldering it into a PCB. The formeris what the switch was designed for, the latter is a bad idea.
BobTPH
Joined Jun 5, 2013
11,617
I am beginning to think you hired a plumbing company to do you soldering.
Look at any modern PCB in a commercial product. 2.54 mm is literally huge compared to the spacing of soldered joints you will find.
Bob
Ya’akov
Joined Jan 27, 2019
10,278
Bob
According to the TS, the vendor suggested a PCB as a solution. They said the terminal spacing was too small for leads and a PCB would be required.
