Soldering problem.
Jac Stone
Joined Mar 11, 2022
10
Hi, I'm new to electronics and circuit design so I'm looking for a bit of information and advice.
I'm designing a little "widget" which has just three components in a circuit, a coin cell battery holder, a sliding micro switch and a LED light, the idea is to have them hand solder together using 0.5mm insulated wire. The problem is with the micro switch, it seems impossible to find a 2 pin switch ( I've search Alibaba for weeks) all the switches are two way with the common pin in the center, the space between the common pin and the other pins is only 2.5mm and the soldering company says they are too close together for soldering.SMALL SWITCH.jpg
Is there any other way to connect a 0.5mm wire to the pins, why would they make a micro switch if it is to small to use solder?
Any advise would be much appreciated.
Ya’akov
Joined Jan 27, 2019
10,300
Welcome to AAC.
First, just a detail but "microswitch" refers to a snap action switch of the sort used as a limit or sensitive detection switch. What you have there is an SPDT (Single Pole Double Throw) slide switch. It could be called "sub-miniature" but not "micro".
2.5(4)mm is the standard spacing for PCB mounting. It's 1/10" which is why it became the standard. It is very easy solder in place.
I don't understand how you want to solder them together, could you draw a picture? And, I don't know what your "soldering company" refers to, could you clarify?
You are not going to find a two pin slide switch, it would make no sense to manufacture since mechanically the space on each side of the center needs to be the same and adding the contact provide both switching flexibility and mechanical strength.
BobTPH
Joined Jun 5, 2013
11,655
That switch is intended for PCB mounting. If you intend to use wires, get a panel mount switch, these are made to have wires soldered to them.
Bob
Jac Stone
Joined Mar 11, 2022
10
Welcome to AAC.
Yaakov hi thanks for your reply, yes you are correct it is a Single Pole Double Throw switch. I just have a very simple circuit but it has to go into a very narrow space. Here is a picture of the components ( not to scale )SOLDER DIAGRAM.jpgInitially just soldered them myself but as I needed a lot doing I sent a sample to a hand solder company who said they could not make solder joints at C and D because the contact pins were too close together. They said they would need to mount the switch on a PCB which needs to be 1.mm thick and the solder would be around 1.5mm thick, (the wire is 0.5mm). The data sheet diagram shows the switch to be 2.45mm + 1.05mm high excluding the sliding knob. Using these figures that would make the height from the base of the switch to the top of the solder 6mm, this would be too high for the space available so is there another way to do this? Any alternate ideas welcome.for forum.jpg
Ya’akov
Joined Jan 27, 2019
10,300
I would say design a small PCB and have it fabricated. They are cheap and it would improve the reliability a lot.
What is this, exactly? What housing will it be in?
Ya’akov
Joined Jan 27, 2019
10,300
I should add you can get PCBs as thin as .2mm and you would route the switch to the edge and solder there, not on the terminals. The pads for soldering would be further apart than the switch terminals.
Tonyr1084
Joined Sep 24, 2015
9,744
IF they said they "Could Not Make" solder joints what they probably mean is that they 'WOULDN'T'. Likely their solder tech's are not so skilled as to do what is called "Dead Bug" solder work. Personally I wouldn't want to do business with them. HOWEVER, it's likely many if not most solder houses would refuse to do this sort of build.
As Yaakov suggests, having a PCB fabricated would greatly increase reliability and durability of your circuit. All that is needed is to know the layout and space available for such components. Shouldn't be a big expense, minor is more likely.
BobTPH
Joined Jun 5, 2013
11,655
I suspect that they refused to do this because of its fragility. They don’t want to be blamed when it shorts or breaks off during installation.
Bob
Jac Stone
Joined Mar 11, 2022
10
Thanks again for your help, the parts have to go into a case about the size of a chunky square watch will I be able to get a PCB fabricated which is small enough. I know nothing about designing PCBs would the company who fabricates them be able to design it if I send them the data sheet for the switch?a3.jpga3.jpga1.PNGa5.jpg
Jac Stone
Joined Mar 11, 2022
10
Thanks, the battery holder and LED are not a problem, it's just the switch due to the height of the case which it has to go in which can't be altered.
Jac Stone
Joined Mar 11, 2022
10
DickCappels
Joined Aug 21, 2008
10,661
That has to do with the battery voltage vs LED current. You are unlikely to need a resistor in series with a white LED, but if it were a red LED, for example, would have to be careful limiting the current.
Just looking out for you.
Jac Stone
Joined Mar 11, 2022
10
Ah, that's way over my head but thanks, I learn something new every day.
Jac Stone
Joined Mar 11, 2022
10
I don't understand how mounting the switch on a PCB would help, I'm a complete novice but surely the switch terminals are still the same distance apart so how does it make them easier to solder??
BobTPH
Joined Jun 5, 2013
11,655
I told you why they won’t solder them. It has nothing to do with the dustance beween the pins. The were using a polite excuse instead of telling you it was a bad design. I just finished soldering 4 boards with an IC with pins 0.65 mm apart. And that is not the smallest. You pins are 2.54 mm or 4 times as far apart as the ones I just soldered. It id soldering them to wires unsupported that the object to, and for good reason.
If you could find a switch that is designed for panel mount, which is what you are doing, it would be solderable. They use stiffer pins with an eye like a needle that you thread the wire through.
Bob
