Soldering help
fixit7
Joined Jun 2, 2019
12
I could use some help with soldering.
I would like to learn how to solder these 2 wires while being able to slip
the shrink tubing over the soldered connection.
Thanks.
SamR
Joined Mar 19, 2019
5,535
First you slip shrink tube over the wire large enough to cover the soldered splice. Then you do this.
Then you solder.
Then slide the shrink tube over the splice and hold a match under it to shrink it to fit.
dendad
Joined Feb 20, 2016
4,641
Make sure the heat shring is first slid onto one wire, but a fair way from the joint so it does not get hot.
Then, twist the wires together for mechanical strength, ensuring the wires are thinner than the insulation.
Solder the wires, and wait for them to cool down before sliding the heat shrink over the joint.
Then shrink it down.
I mainly use "Twin Wall" heatshrink now. That is the type that has a layer of hot melt glue inside so it shrinks and seals well.
djsfantasi
Joined Apr 11, 2010
9,237
I’ll just add my two cents. Dendad made an important point. The heat shrink tubing MUST be far enough away from the splice. Otherwise when you solder, the tubing shrinks into the wire and you won’t be able to slide it over the soldered splice.
Ask me how I know.
fixit7
Joined Jun 2, 2019
12
Yeah, I had the shrink tubing shrink a little and could not slide it over.
Tried to trim off the shrunk part, but it was a lost cause. :)
fixit7
Joined Jun 2, 2019
12
Then you solder.
Thanks. I was doing it as shown, but I had the wire stripped only about .5 inch.
So, the twisted wires always came apart before I could solder them.
Andy
SamR
Joined Mar 19, 2019
5,535
Telling would ruin all the fun of finding out for yourself. ;) It's just one of those things that must be experienced to get the full joy of it!
