Solder points on PCB not taking solder
john2k
Joined Nov 14, 2019
219
I'm trying to add some solder to solder points of SMS legs on a PCB but it just isn't taking the solder. The solder seems to keep bubbling up. Any advice?
38,764
Lead free doesn't solder as readily as leaded so get some containing lead if you can.
There is absolutely no health hazard from using leaded solder.
35,125
Try increasing the temperature of your soldering iron to 800°F or 425°C and use tin-lead solder to get it flowing.
bassbindevil
Joined Jan 23, 2014
924
Try scrubbing the pad with a "rust eraser" pen (has a bundle of stiff fiberglass bristles, got mine from the auto parts store in the autobody section). Maybe there's some oxide layer that prevents solder sticking.
