Hello Everyone,
I’m an artist working on a project that I would like to add LEDs that are solar powered. This would be completely off grid.
I am planning on using 100 x 0.025 watt LEDs throughout my outdoor sculpture. These are off the shelf sealed “trailer lighting”. Each is individually sealed in plastic with two wires (1” x 3/4”) ready to hook up to a 12v battery. http://www.ledtrailerlights.com/cm-hd34003-mini-clearance-marker-light-3-leds.htm
I would like to have this work every night for a minimum of 7-8 hrs. I am designing and building it therefore I have leeway on the panel size and battery size. It will be south facing with no obstacles. It will be located in Ottawa Canada.
My questions are: Is this even possible? Will I be able to store extra power for cloudy days in a large battery/ies? Would it be better if the lights came on for 5 minutes with a motion sensor and then off for power conservation? What size panel and battery will I need?
Thank you for your help!
