Solar panel Cooling unit help
Hassan Wahaj Malik
Joined Oct 15, 2017
45
I have a 100W panel powering a peltier cooler and 2 Dc fans.
Th epeltier cooler uses 12V and 3Amps where as fans use 12V and 0.11A.
I am using a dc-to-dc buck converter to power the peltier cooler but i am kinda confused what i should use to power my fans with? The voltage regulator LM718CV3 supplies 1.5A which is too much for the fan and i believe it might smoke it. Any help would be appreciated.
AlbertHall
Joined Jun 4, 2014
12,653
But it’s suppying 3Amps
It is supplying 12V and is capable of supplying a maximum of 3A. If you connect a 12V, 0.11A fan to it the fan will draw 0.11A and work just fine.
A car battery provides 12V and is capable of supplying 100's of amps, but the sidelight on the car (possibly needing just 0.5A) doesn't blow up when switched on.
be80be
Joined Jul 5, 2008
2,395
One better the light bulb in a lamp 20 amp wall outlet these newer led bulbs are less then 100 mA they last for a year or more.
Same as drinking water you can only drink as much as you can hold the fan will only sip it's .11amp
