Solar panel as light sensor
dendad
Joined Feb 20, 2016
4,641
Grab a solar powered garden light LED string and it already does exactly what you want. There are data sheets around for the common control ICs used in them. That may be a good place to start.
ian field
Joined Oct 27, 2012
6,536
Most of which only need 1 nickel cell, and the inverter oscillator produces enough voltage for any colour LED.
Most use a chip nowadays, and the solar panel input also senses whether to turn the LED on. Earlier discrete component types mostly used a complimentary astable driving the inductor. LDR use were common early on, but variants involving an extra transistor evolved over time.
18,135
I was going to say it's a good place to end also: Just hack a landscape light to turn on the lantern instead of the LED it came with. But then it dawned on me that the LED in the lantern likely uses a LOT more current than a little landscape light. The landscape light may work for the switching, probably you'd want to add a transistor, but it won't be able to drive the LED with its tiny boost circuit.
Yardy
Joined Mar 26, 2019
17
The thing is I already have the lantern - all I want to do is charge it with a small panel a d then switch it on using said panel
Yardy
Joined Mar 26, 2019
17
Yes I still have the cable - I was thinking of cutting it and connecting the panel that way - the diagram I posted of the circuit may require a different diode to prevent the panel drawing power at night
Yardy
Joined Mar 26, 2019
17
Yes that's my plan Ive seen things like flourescent bulbs and tubes run off joule thiefs- I understand that it's different to solar - could I just take out the AC gear and hook up the DC output as long as I add resistors
Ya’akov
Joined Jan 27, 2019
10,283
As a rule, using a connector which normally has mains voltages on it for love voltage DC is bad. That connector isn't unusual, and if someone connects an intact line cord, electric shock and/or fire is a possibility.
There is a good chance that latter is unsafe even as it is. Many of that type have a capacitive dropper supply and they are not isolated form the mains. All very scary.
ian field
Joined Oct 27, 2012
6,536
Non-isolated droppers violate the terms of this forum.
Bernard
Joined Aug 7, 2008
5,784
Let's not get excited, the AC is left behind and might have a SMPS inside. As almost always we need more information on what is on the inside.
