Solar charger controller
Ya’akov
Joined Jan 27, 2019
10,259
But 6v solar panel smaller.isn't it?
The voltage of a PV panel is directly propoptional to the number of cells in it, the current capacity is directly proportional to the area of the cells.
So a 6V@6A panel would be half the size, probably about 500x500cm.
It would also be half the power.
Ian0
Joined Aug 7, 2020
13,158
The sun shines at a convenient 1kW per square metre, and panels are about 20% efficient, therefore 200W per square metre output.
There are a lot of fake panels on ebay, claiming all sorts of ridiculous output powers.
sghioto
Joined Dec 31, 2017
8,634
This panel from Amazon rated 120 watt.
BougeRV 120 Watts Monocrystalline Solar Panel with Mounting Z Brackets, 12 Volts Mono Solar Cell Charger High Efficiency Module for RV Trailer Boat Off Grid
Ya’akov
Joined Jan 27, 2019
10,259
I don’t know if this panel is specified properly, but pretty much all the panels I can find from high reputation manufacturers rated with this current capacity hover right around 1m x 500cm.
It’s been quite a while since I needed to buy PV panels, though, so it is possible that some are better. Still, that seems to imply a much higher efficiency than seems reasonable.
I really don’t know. I guess I just don’t have enough up to date information to counter my experience, but I don’t have it so I leave it to the reader to work out what’s correct.
Thanks for pointing it out though.
Ya’akov
Joined Jan 27, 2019
10,259
Are you saying 1 meter tall by 500 centimeters wide? That's appx 3 ft by 16ft
Can you post the link to one you are referencing at 1m x 500cm ?
Ha! I kept typing the same error! 50cm not 500cm. Wow. Doing too many things at once, maybe? I apologize.
Maybe I am just a physicist at heart, order of magnitude and all that,
Wow. No wonder you were so confused. I need to pay more attention to zeroes, I think.
Thanks for pointing that out. 1m x .5m not 1m x 5m.
I think I was converting to mm and typing in cm.
bassbindevil
Joined Jan 23, 2014
922
The main reason that solar charge controllers provide an output terminal is for automatic lighting. Mine has the settings: a) always on, b) "load on after sunset and closed after setting hours", c) "dusk to dawn".
Tom gayle
Joined Sep 20, 2021
84
Actually, it's 50cm?
