So I am trying to learn Python
Wendy
Joined Mar 24, 2008
23,857
And I cannot get this program to work. Any ideas?
Code:
sin60=0.866025
w=input('width?')
a = w / 2
b = a / sin60
c = b / 2
r = ( b / 2 ) + c
r
MrSalts
Joined Apr 2, 2020
2,767
Also change input line to...
print("Enter Width:")
w=float(input())
If you are using an online simulator of Python, you cannot use the input command.
Wendy
Joined Mar 24, 2008
23,857
Actually I can and did, I also used input to freeze the display so I can view the result.
Code:
sin60 = float(0.866025)
w = float(input('width?'))
a = w / 2
b = a / sin60
c = b / 2
r = ( b / 2 ) + c
print(r/2)
z=input()
Wendy
Joined Mar 24, 2008
23,857
The weird part is I wrote the code using notepad then changed the ext to .PY after saving it. Clunky but I am learning. Hey, it was my first real program in Python. Now on to loops.
MrSalts
Joined Apr 2, 2020
2,767
If you have Python installed on a windows machine, you should be able to right click on a .py script and select "edit" - the Idle IDE should open. You can also look at your start menu to see if the windows IDE popped up in there when you installed Python. Last option, type "idle" in the start search box. All (any) should work.
The IDE us very easy to use and there is an IDLE shell that opens each time you click run to test your script.
