SMPS repair - fuse blows
dimakis_f
Joined Oct 28, 2016
Hello everyone.
I am working on an old CRT TV.
The TV set does not start at all.
I have checked the smps, and the 800mA fuse ( SI624 ) on the shematic , near the main capacitor , keeps blowing .
I changed the electrolitic capacitors on the primary side,
changed the TDA4605 and the PowerMOS transistor.
All diodes are OK and 300 volt is measured on main capacitor ( C626 ).
The PowerMOS transistor seems short circuit and the fuse blows.
I have attached the shematic of the board.
Any help will be appreciated.
Thank you very much.
Fotis D.
dimakis_f
Joined Oct 28, 2016
The transistor is on the first page, T644 , and is the BUZ90A.
When i remove it and test , off the board , it's ok.
Then put it back, turn on the tv set, fuse blows and T644 seems short circuit again.
Is there any chance that the SMPS transformer TR651 causes the problem ?
When i first checked this tv set, i could measure some voltages on the secondary of the SMPS,
but was half of the appropriate values (for example 4 Volts instead of 8.5 at point +E on the schematic).
Thank you.
Lyonspride
Joined Jan 6, 2014
137
Is there an MOV in the circuit for over voltage protection? Has this gone full short cct? Quite a common problem here in the UK with devices being made in China for 220v and then shipped out to the UK where we have a 240v (+/-10%) supply, the MOV gradually becomes more and more sensitive until it becomes a complete short and blows the fuses.
wayneh
Joined Sep 9, 2010
18,155
I don't understand what you mean. If the voltage on the gate is enough, that transistor will turn on and conduct. That's what it's supposed to do, under control of the gate voltage. I would not call that a short.
If the control of the gate voltage is at fault, you need to trace that down. You might try disconnecting the gate and controlling it yourself, by connecting it to its source pin. It should stop conducting.
Dodgydave
Joined Jun 22, 2012
11,395
Check D647/8 flyback diodes Byv16 for s/c, also remove the transformer winding outputs, there could be shorts on the supply lines causing the fuse to blow.
