SMPS design using UCC28700, Not getting the proper output.
ashokraj
Joined Feb 1, 2018
151
I have designed a circuit based on web bench power supply design from texas instrument in TINA. web bench power supply
I could not able to get the appropriate voltage(24V) at the output of secondary coil. I suspect the problem is in transformer. Is there a way I can custom design a transformer in TINA?
If transformer is not the problem I am open for corrections.
I have attached my TINA design file below.
Please provide some insights.
Dodgydave
Joined Jun 22, 2012
11,395
The two resistors R12, R13 set the output voltage, the Vs pin requires 4V to set the output, your values are approx 20V increase R12. Also the three 4M start up resistors are too high, just use one 4M.
Ian0
Joined Aug 7, 2020
13,317
Three resistors are in series because a single one doesn't have enough voltage rating if it's a 1206 or smaller - but they won't flash over in a simulation!
