SMPS component function question
John Czerwinski
Joined Jun 19, 2017
71
I'm new to the SMPS topic and have the basic understanding, in a block diagram sense. I'm working on repairing a SMPS for an arcade game (it's a typical "switcher") and narrowed the problem to two resistors that have failed open (R2 and R3).
My two questions are:
1. What are the functions of the 2 100K 2W resistors (R2 and R3) below?
2. On the +5 VDC power rail, what's the function of the 50 ohm resistor (R29) between +5 V and GND?
DickCappels
Joined Aug 21, 2008
10,662
1. They are bleeder resistors so that when the input voltage is switched off the capacitors are discharged.
2. It may be left over from an earlier drawing - the resistor would be a nominal load for testing and things like that.
John Czerwinski
Joined Jun 19, 2017
71
Thank you for the response.
on #2, on the actual PCB I have, it has the 50ohm resistor between the +5 and GND. When troubleshooting the dead SMPS, I thought there was a short between the rails but saw it was the 50ohm resistor. To verify, I took it out of circuit and there was no connection between the rails anymore. I think I've seen this before, but have no idea why it's there
Juhahoo
Joined Jun 3, 2019
302
Some power supplies require a constant minimum load on them to maintain output stability, specially fly-back converters, 50 ohm load would set constant current flow of 100mA @5V. There is one resistor load on each output... R29, R26, R27
