SMPS circuit for LTspice
FuseFuse
Joined Feb 8, 2017
37
I'm searching for an example circuit to be run on LTSpice with a SMPS together with a common mode choke. The idea is to run a transient simulation in order to see the effect of this latest component on output voltage (noise reduction).
Do you have anything to suggest?
Thank you
Alec_t
Joined Sep 17, 2013
15,167
The test jigs (example circuits) provided for the SMPS ICs in the LTS "Power Products" folder may be useful.
eetech00
Joined Jun 8, 2013
4,749
Thank you
Suggestion....First use AC analysis to check the filter Freq response/Attenuation.
For transient test, you could use a DC voltage source, with a varying quantity of superimposed ripple, to simulate an SMPS output. Connect the choke to the simulated output along with a typical load.
Alec_t
Joined Sep 17, 2013
15,167
Click on a SMPS device listed in the Power Products folder, then click on the 'Open this macromodel's example circuit' box to the right of the device symbol.
