SMD Resistors
Dritech
Joined Sep 21, 2011
907
Hi all,
I have a PCB with SMD components. I noticed that there are many resistors is parallel. For instance, two 300ohms SMD resistors are used as a current limiter for an LED. Why is that? Why they did not use a single resistor?
Thanks in advance.
ericgibbs
Joined Jan 29, 2010
21,442
hi Dri,
Its possible the dissipation in a single SMT of that case size, does not have the required heat dissipation, so two, of double the resistance value are connected in parallel.?
ISB123
Joined May 21, 2014
1,236
If they are connected in series then they probably had lots of 300 Ohm R but didn't have any 600 Ohm R so they connected them in series to save on budget?
Dritech
Joined Sep 21, 2011
907
Thanks for the replies. Ericgibbs answer makes sense for the LED current limiter resistor since this PCB is powered using 12V without a regulator.
But I also noticed the same technique used with buttons. This PCB has surface mount buttons which are resistance coded (for instance when button A is pressed it outputs 300ohms... when button B is pressed it outputs 600ohms etc.). In this case power is not an issue since it will most probably be connected to a voltage divider and to an ADC. So in this case why are they connected in parallel? could it be budget wise or to increase efficiency when placing the SMD components?
