SMD resistor protection chip blew can I solder new one on top?
eddie500
Joined Nov 5, 2011
45
On a circuit board they put tiny 4 ohm resistor that blows if there is too much current. I was told it was designed this way as a fuse. Usually it blows when some wires short or touch each other.
Recently the resistor blew and I am getting 6,000,000 ohms while connected to the circuit, this is because it is reading through the circuit board as I have checked the resistance before without the resistor installed.
My question is it would be very easy for me just to solder a new 4 ohm resistor on top of this one then to remove the old one.
If I do this, soldering the new one on top to the legs of the old one. Will this be OK? Will the 4 ohm resistor still act as a fuse for over current?
Since the other resistor is blown and is reading 6,000,000 ohms instead of 4 ohms, I assume it has been melted internally and is not doing anything anymore. So soldering a new one to its legs, would be OK.
Just checking before I do this and then it doesn't work correctly as a fuse anymore. \
This is the resistor that blew and what I will be soldering on top of the old one.
RES SMD 3.9 OHM 5% 1/10W 0603
It would really save me a lot of time and damage to my board if I can just solder a new one over the blown one. These resistors are so tiny and hard to solder / unsolder.
renemonte
Joined Oct 7, 2016
16
go ahead!
ErnieM
Joined Apr 24, 2011
8,415
Well... It depends. The original resistor may need to be directly mounted to the PCB so it has a path for heat to go.
How small is small? How much current normally runs thru this resistor?
eddie500
Joined Nov 5, 2011
45
Not sure how much current but it is for the 5 volt Halls of an electric motor for an electric bike. The resistor blows like if one of the halls wires touches the phase wires while operating the bike, usually by damage to the wires.
The resistor is so tiny you can hardly see it. An 0603 size SMD.
I soldered on top of the old one and everything works and reads the correct ohms at 4.9.
I just soldered to the legs on top of the old one, so the old blown resistor is still in place. My concern is if doing this would somehow cause a problem with the new resistor not blowing to protect the circuit board in case of over current.
jjmalove
Joined Jul 6, 2016
51
You are good assuming one thing: The old one is still soldered to the board and the traces/pads below it are intact. When things go boom in electronics sometimes they damage the pads below them.
Assuming the board itself it ok, then yes you can solder a resistor directly to the top of the existing resistor. You will create a parallel circuit of the two resistors. The formula is (R1 x R2)/(R1 + R2). In this case (4 x 6000000)/(4 + 6000000). Your net resistance will be 3.999997 ohms.
Obviously the margins of error on your resistors are far larger than the change showed, so for all purposes the new value will be 4 ohms, just thought spelling it out for you would help explain WHY it will work.
