SMD Resistor Marking
Kjeldgaard
Joined Apr 7, 2016
476
At first glance, these are some slightly funny markings.
After the usual three significant figures, I get the following:
8871 ~ 8.87 kΩ
R681 ~ 0.681 Ω
And both of the above resistors are common E96 values.
WBahn
Joined Mar 31, 2012
32,823
I agree that it appears to be an '8', though I can't imagine why they chose that glyph.
But R681 should be a 680 Ω resistor (likely a 5% tolerance), not 681 Ω. A 681 Ω resistor (likely a 1%) should be marked 6810 (the leading 'R' is not significant). The last digit should always be the multiplier, though I have seen a very few resistors where the multiplier was left off if it was a zero, which makes no sense as it creates ambiguity.
