Hello, I'm Sid and I'm currently in the process of doing my GCSE coursework. The project I am doing is a solar mobile charger. Although I have found very easy circuits to use, my electronics teacher said I needed more challenging process components, so I have combined a simple circuit with a more challenging circuit using an IC 555. Here are the links to the said circuits.
Challenging IC 555 circuit
PARTS LIST
Resistors (all ¼-watt, ± 5% Carbon)
R1 = 390 Ω
R2 = 680 Ω
R3 = 39 Ω/1W
R4 = 27 KΩ
R5 = 47 KΩ
R6 = 3.3 KΩ
R7 = 100 Ω/1W
VR1, VR2 = 20 KΩ
Capacitors
C1 = 0.001 µF (ceramic disc)
C2 = 0.01 µF (ceramic disc)
C3 = 4.7 µF/25V (Electrolytic )
Semiconductors
IC1 = NE555 timer IC
T1 = SL100 or any Medium power general purpose NPN transistor like: 2N4922 , 2N4921,2N4238, FCX1053A
ZD1 = 5.6 V/1W
LED1
Miscellaneous
SW1 = On/off switch
1.5V*8 AA cells
Mobile connector
And then the simple solar charger
My combination of the two circuits using circuit wizard
The phone battery will be connected in series between the cathode of D3 and ground. The filament lamp there was my attempt to represent a charging battery. The IPhone charging requirements are 5v and 250-500mA but as you can see, I'm only getting ~1v and 162mA and I am not able to understand why. It seems that the higher current draw a component possesses, the lower the voltage drops. If anyone could help me here it would be greatly appreciated and if anyone has any improvements it would be of great help (keep in mind I must keep the 555 IC). V1 and V2 are just representing the solar panels. The transistor model is set to "Ideal" on circuit wizard on my circuit.
Links to the webpages/sources I used for my circuits.
http://www.techulator.com/resources/10562-Make-your-own-Solar-mobile-charger.aspx
http://electronicsproject.org/mobile-cellphone-charger/
PARTS LIST
R1 = 390 Ω
R2 = 680 Ω
R3 = 39 Ω/1W
R4 = 27 KΩ
R5 = 47 KΩ
R6 = 3.3 KΩ
R7 = 100 Ω/1W
VR1, VR2 = 20 KΩ
Capacitors
Semiconductors
ZD1 = 5.6 V/1W
LED1
Miscellaneous
SW1 = On/off switch
1.5V*8 AA cells
Mobile connector
