Bit of a beginner here, I've created two PCBs using easyeda + JLCPCB with their SMT process. Both have worked great. I'm working on a 3rd design but its smaller than their SMT process supports. To that end I've made a larger board with cutouts/tabs:
The grey parts are the cut out. The entire board size is 43x26mm, the inner board is 33x16mm. The 4 cutouts are 2mm wide and the corner tabs are ~2.8mm thick. Do you think this will print/assemble correctly? Do I need anything special to cleanly cut the inner PCB out of the frame? Should I do something completely different?
I've posted a similar thread in the easyeda/JLCPCB forums, but so far it's been quiet. Any thoughts/ideas appreciated.
