Were are 1uF -3uF smt electrolytics typically found? Aren't MLCCs better than electrolytics?
P Thread Starter pager48 Joined Nov 25, 2018 161 May 27, 2019 #1 Were are 1uF -3uF smt electrolytics typically found? Aren't MLCCs better than electrolytics?
J jpanhalt Joined Jan 18, 2008 11,087 May 27, 2019 #2 Here are some sources: 1) 5325 Tantalum SMD in 1 uf to 3 uF (9808 including TH): https://www.digikey.com/products/en...03b&quantity=&ColumnSort=0&page=1&pageSize=25 2) 2847 Aluminum electrolytic in that range: https://www.digikey.com/products/en...03a&quantity=&ColumnSort=0&page=1&pageSize=25 3) One can often I substitute MLCC, but not always. For example, some voltage regulators need the esr of an electrolytic to work properly (not oscillate).
danadak Joined Mar 10, 2018 4,057 May 27, 2019 #3 In terms of ESR for same C valued cap - But MLCCs have a problem, their C = f(V) https://pdfserv.maximintegrated.com/en/an/AN6014.pdf Regards, Dana.
AnalogKid Joined Aug 1, 2013 12,139 May 27, 2019 #5 His questions might be: Where are they used? And why, if ceramics are "better"? ak
wayneh Joined Sep 9, 2010 18,105 May 27, 2019 #6 danadak said: C vs Voltage Ceramics Regards, Dana. Click to expand... Thanks for this, I had no idea the sag was that pronounced. No wonder capacitor-based timers are so bad.
danadak Joined Mar 10, 2018 4,057 May 27, 2019 #7 Its peculiar to Ceramics, so film, mylar, teflon, maybe better choice. T dependence in datasheets a must read. Or now many processors with onboard osc "trimmed" at production test a much better timing element. In the couple of % range. Regards, Dana.
