Want to use a small transformer that produces 8 / 16 / 24 VAC from 120VAC line voltage and rectify the 8V AC output to DC to use with a cheap pressure transducer that wants 6.5 VDC input power. Bridge rectifiers are readily available on Digikey.com as small integrated circuits, very inexpensive. There is an online calculator for sizing a smoothing capacitor at <redacted by moderator> but there is no discussion of how smooth the ripple voltage will be made or distinction between the output capacity of the transformer vs. the DC load requirement (in amps), so I don't know if I need a capacitor of a few micro-farads or hundreds of micro-farads. The transformer can produce more than 1 amp DC , but the DC current needed by the pressure transducer is probably only 20 mA. Also not sure how accurate the 6.5 VDC power to the pressure needs to be or what ripple in the DC voltage is tolerable. Would appreciate if someone with experience in these matters can offer some comments. Of course, I can't and don't expect anyone to provide precise answers when they aren't given by the manufacturer of the devices (like the pressure transducer, for example), but I am inexperienced and hope that someone familiar with these topics can offer some comments.
