single to 3 phase vfd cicuit
jonnydolt
Joined Oct 23, 2015
145
Hi Guys thanks for reading.I have a 3 phase compressor with a 5.5kw motor,this will run on single phase via a 7.5kw vfd. I will need to run a whole new circuit but I also want to have an additional 15amp double gpo right next to it.Can this be done with 1 cable or will I need 2 ? and what size breaker/'s, cable/'s and gpo's would you use? The cable length will be 10 meters from the meter box to the power points and run in conduit 240 volts
MaxHeadRoom
Joined Jul 18, 2013
30,665
There must be local reg's that you can consult for your part of AU.
In N.A., this would Ideally be done with separate conductors/breakers etc.
Max.
jpanhalt
Joined Jan 18, 2008
11,087
A rotary phase converter ? aren't they bulky and really expensive ?The vfd is small and only $280.AU
Times have probably changed. I built mine in the 80's from a used 5 HP 3-phase motor. My situation was perhaps different. I had 3, 3-phase machines. So, the single converter just ran and I could run anything or combination of machines off it. I thought maybe you wanted a VFD to change speed, which I would not do with an air compressor.
I didn't realize that a 7.5 , continuous duty VFD was so cheap today.
