Hey Everyone.
I try to implement a non-inverting amplifier with single supply.
My signal is sine wave at 50KHz.
I try to simulate this circuit with ideal op-amp. I use the program Tina-TI and LT-SPICE
Tina-TI
and I get good resault:
LT-SPICE
The resault (green->Vin , Blue -> Vout)
After this I tried to simulate real Op-Amp IC, LMV654 and LMH6629, with TINA-TI but I didn't get good resault, you can see the voltage level of the output signal:
I try to change the frequency of the input signal, change the capacitors and resistors value but the resaults were not good. not like the Simulation with ideal op-amp.
Thank you very much
Tina-TI
LT-SPICE
Thank you very much
