Single pulse generation from TTL change of state
chrisathome
Joined Oct 28, 2017
5
I need to generate a pulse of say 500 to 1000ms when an input changes state from TTL high (+5v) to low or vice versa. The input will be high or low continuously for hours at a time, I just need to act at the transition. The pulse will be used to momentarily operate an SPST 5v coil relay driving a usb keyboard matrix decoder to interface with software, i.e. it replicates specific keyboard keypresses. It doesn't matter if several pulses are sent at each transition, the software is tolerant.
I have to build a number of these interfaces to connect to external equipment, all of which will be acting on the same matrix decoder. Some interfaces will act on a rising edge (I.e. the input going high) and some on a falling edge. As I said before, the input lines will be either high or low for hours or even days at a time, its the state change I'm interested in. I don't care if I use TTL or CMOS (or whatever the modern equivalent is).
Its over 30 years since I did any logic work so I'm very rusty! Any help would be appreciated.
Many thanks
Christopher
dl324
Joined Mar 30, 2015
18,465
Welcome to AAC!
Use your choice of TTL or CMOS one shots (74121, CD4538, NE555, LMC555). Half a second is a bit long for using a CMOS gate with an RC network.
You'll need an edge detector circuit to trigger from rising or falling edges from the same trigger input.
