Single Power Supply for 8 load resistors
hodakaracer96
Joined Feb 7, 2017
7
I am trying to build a simple circuit where 8 load resistors dissipate the same energy each (lets say 500mW). I want to buy a cheap DC power supply that can be remotely turned on and off (Mean Well RSP-75-12). I don't want to buy 8 power supplies unless I have to. I plan to put a potentiometer in series such that I can adjust the power dissipated by the load resistors.
My original plan would be to put these load resistors in parallel. One issue with that is I want modularity. For instance, I may only have 4 running at a time, with the other 4 having open leads. I would like a circuit that is indifferent to this, such that I don't have to re-calibrate the power dissipation every time. Are there any cool circuit tricks to accomplish this?
-David
Papabravo
Joined Feb 24, 2006
22,113
I'm having a hard time understanding your description. Could you possibly sketch up a diagram of your idea. It would help a great deal. Thanks a lot
hodakaracer96
Joined Feb 7, 2017
7
Does that help? Each resistor is essentially a heater for an 8 up test. I want each resistor to dissipate 500mW, and hopefully not have to re-calibrate every time I take a unit on or off.
wayneh
Joined Sep 9, 2010
18,170
If the power supply is set to a constant voltage, and is capable of supplying the maximum current for all loads simultaneously, then disconnecting some or all of the loads will have little or no effect on the voltage to the remaining loads.
Everything changes if you have a pot in series with more than one load. [update]. Yeah, your drawing won't work. You need to adjust the supply voltage instead. A pot to adjust that much power would be expensive and won't allow you to remove loads without readjustment.
EM Fields
Joined Jun 8, 2016
578
Since the RSP-75-12 is a voltage source, its output voltage will remain constant regardless of the load resistance to which it's connected (until its output current specification is exceeded) so, for the configuration you describe, you may switch loads with impunity.
wayneh
Joined Sep 9, 2010
18,170
See his diagram that includes a series pot. Won't work.
hodakaracer96
Joined Feb 7, 2017
7
Hi, thanks for the responses. Still not sure what to do.
one other feature that I didn't mention is that I would like to adjust the power dissipation if necessary (from 300-800mW). The load resistors are inside my devices, I cannot change the 200 ohm number for the 8 devices.
hodakaracer96
Joined Feb 7, 2017
7
That could work (same circuit, get rid of the potentiometer right?). I need one with "remote on/off", was hoping to find something cheap.
EM Fields
Joined Jun 8, 2016
578
Indeed.
My interpretation was that he wanted to use a rheostat in series with each switched load and that all of the loads and their series rheostats would be in parallel, but his schematic belies my belief.
Joined Nov 30, 2010
18,224
I'm hoping the T.S can figure out he doesn't need a pot if he uses the right resistors.:)
I was also hoping that the T.S. told us what he needed in the first place instead giving us the run-around.:(
hodakaracer96
Joined Feb 7, 2017
7
Hold the phone. Realization...If I get potentiometers for each load then this whole problem goes away and I don't need a variable voltage power supply. I'd calibrate each UUT to my 500mW and be done. Sorry for thinking stupidly out loud on the forum.
EM Fields
Joined Jun 8, 2016
578
There are still two problems in that you stated, in post #10, that you wanted to be able to to vary the load's dissipation from 300 milliwatts to 800 milliwatts.
The first problem is that a 200 ohm load with 12 volts across it can only dissipate 720 milliwatts, so your 800 milliwatt specification is unattainable.
The second problem is that you're now stating that the goal is to get each load to dissipate a fixed 500 milliwatts.
What is it you really want to do?
wayneh
Joined Sep 9, 2010
18,170
I also think you're in for a surprise when you price out 8 pots rated for >1W. They'll need to have low temperature drift, since they'll heat up under load, as will your 200Ω resistors. If you need precision and accuracy, you might need individual current or voltage controllers on each leg.
