Single control PSU able to output all the way from +15V to -15V
atferrari
Joined Jan 6, 2004
5,033
Here's the LTspice simulation of the circuit I mentioned for 0 to 100% U2 pot rotation.
The Sziklai pair output gives a 3A maximum current.
The op amp can be just about any rail-rail output type.
If the load current is less than 200mA, then you only need Q1 and Q3.
@crutschow
Thanks Carl!!
My intention of using the buffer built as per post #9 above, was a failure. After ditching several very old potentiometers, I found finally it also had the output transistors reversed. A good design can do nothing against wrong hardware.
So in less than one hour your circuit was up and running. No rail to rail here so I used a TL071. The non-Sziklai version obviously worked at the first try, with a very small motor (current is around 30 mA).
As usual yours was a great help.
Gracias again.
