Simulation of Load and Line regulation of LDO
Janani_Rajkiran
Joined Nov 1, 2016
46
Hi!
I need to simulate the Load and Line regulation of the following regulators:
R-78C.0-1-0_19-5V
tps780_5-3.3V
ADR3412-3.3-2.2V
ADP1706_5-3.3
Is there a way to do this?
MrAl
Joined Jun 17, 2014
13,888
Yes, change the load from min to max, change the input from min to max.
Usual tests for good regulators would be to very the input in three steps:
min, half, and max,
and vary the load in three steps:
min, half, and full.
You should take numbers for all three inputs and all three outputs, forming 9 separate cases.
You can then compare the results to see how good the regulator works.
GopherT
Joined Nov 23, 2012
8,009
Hi!
R-78C.0-1-0_19-5V
tps780_5-3.3V
ADR3412-3.3-2.2V
ADP1706_5-3.3
Read the DATASHEET for each device. A good DATASHEET will show the test conditions and you'll know exactly how they were tested.
eetech00
Joined Jun 8, 2013
4,746
Hi
Try the manufactures site, search the internet, or make the model yourself.
I can make the model for you but it will take a while. Which simulator are you planning to use?
Janani_Rajkiran
Joined Nov 1, 2016
46
Hi
Thanks. I'm currently using LTSpice. Could you tell me how to model these regulators, so that i could try them out as well?
