Simulation diagram from a Transfer function/difference equation
josh007
Joined Sep 20, 2015
43
Greetings,
I require assistance.
Calculate the difference equation and then Draw the simulation diagram of the below transfer function.
H(z) = Y(z)/X(z) = (0,4142 + 0.4142(z^-1)) /(1,4142 - 05858(z^-1))
I performed the normal procedure to find the difference equation, by cross multiplying and using the delay property of the z-transforms, I finally ended up with:
y(n) = 0,2929x(n) + 0.2929x(n-1) + 0.4137y(n-1)
How do I Draw the simulation diagram?
I don't require the answer but guidance on how to derive the diagram and final answer.
Thanks.
Regards
Joshy
MrAl
Joined Jun 17, 2014
13,864
You can start by making n=0 and then increment it, 1,2,3, etc., up to the required last number where you see at least one cycle or whatever it shows.
You might set y(0)=0 unless you have initial conditions and x(-n) equal to zero in most cases unless you have values for x(-n) and then you would have to run n lower than zero also. You also probably set y(-1)=0 too and all other y with n negative unless those have initial conditions also.
The simulation could be a plot of all y(n) and x(n) just as you would with y=2*t where you plot y vs t, or you could plot y(n) vs n and perhaps y(n) and x(n) vs n (two plots with n running horizontal).
MrAl
Joined Jun 17, 2014
13,864
That's not bad, but how are you getting 0.4137 when you divide 0.5858 by 1.4142 ?
That comes out just a little different than what you show there right?
josh007
Joined Sep 20, 2015
43
Hi MrAI,
you right sir thats wrong it should be y(n) = 0.2929x(n) + 0.2929x(n-1) + 0.4142y(n-1),
I am going to take a pic of my block diagram now.
Gracias.
Joshy
