Simulating pierce crystal oscillator
Faiz Valensi
Joined Jun 16, 2014
7
Im simulating a pierce crystal oscillator on synopsys software. The design that i've made is to achieve 10MHz frequency. The problem is the circuit that ive made doesnt oscillate. Initial condition also been included before the inverter. Is there any error that I've made in this circuit? Thank you
RF = 1M Ohm
R1 = 1k Ohm
C0 = 6p F
Cstray = 5p F
C1 = C2 = 22p F
Pmos W/L = 6u/1u
Nmos W/L = 3u/1u
SLK001
Joined Nov 29, 2011
1,549
Have you ever had an oscillator work in your simulator before? I ask, because an oscillator is fairly difficult to get to start in a simulator. What I do, is place a CLOSING SWITCH that closes at T=0.1 seconds in the base of the active element. Sometimes it works, sometimes it doesn't. Sometimes, changing the switch close time helps.
Also, your circuit isn't easily readable.
ScottWang
Joined Aug 23, 2012
7,501
When you asked for help, but you attached a unreadable value, I'm not sure how our helper how to help you?
Please reattach a clear circuit.
Faiz Valensi
Joined Jun 16, 2014
7
Im working with ring oscillator and also VCO circuit. And it works pretty well, only the pierce crystal oscillator doesnt oscillate
eetech00
Joined Jun 8, 2013
4,706
Hi
Where are you setting initial conditions? I don't see the setting(s) anywhere.
Try setting one side of the inverter (try output side) to 0 volts.
Faiz Valensi
Joined Jun 16, 2014
7
Hi
Hello there.
I already set the initial condition at the input side (to 0 volt).
By the way is there any difference if i set the initial condition at the output side?
eetech00
Joined Jun 8, 2013
4,706
I would follow the rise of the power supply voltage.
Which side of the inverter reaches steady state first based on power up?
Are you able to set the ramp up time of all power sources?
Try setting the power supply voltage source rise time to 25uS.
Are you using the .UIC directive?
I mainly use LTspice and this is usually solved by ramping the power supply or
setting the initial conditions of specific nodes or devices (like caps).
