Simulating a button switch press
John Munroe
Joined Sep 9, 2018
I'm trying to simulate a button press on a remote by shorting the two pins on the tactile switch when an audio signal is received and float them otherwise. I thought the best way would be to use a voltage peak holder and a NPN transistor (but is it?). Here's my simulation and I don't think I'm doing it right:
It looks like I can control the voltage across R4, but is this the circuit for shorting and floating two pins? That is, can I connect the two pins across R4 to achieve the effect? My take is that when the transistor is off, there's a voltage at the collector (V(out_r4n)). If I were to connect the two pins across R4, then the downside pin would be getting a voltage when it's not supposed to. Am I missing something?
Any advice appreciated.
AnalogKid
Joined Aug 1, 2013
12,300
He doesn't mean simulate as in LT spice, he means to duplicate the function of pressing a button with electronic components that short together the buttons contacts without physically touching anything.
ak
Alec_t
Joined Sep 17, 2013
15,171
What does the tactile switch connect to? Does it short something to ground or to the +ve rail?
Perhaps a CD4066 transmission gate would do the job?
John Munroe
Joined Sep 9, 2018
Yes, one terminal is connected to the positive rail and the other is to an input pin. How about a PNP transistor?
Alec_t
Joined Sep 17, 2013
15,171
.... but to pull the input pin up to the +ve rail a PNP would do nicely. Providing the +ve rail is no higher than the MCU supply, no additional level-shifting would be needed.
