Simplify the expression by algebraic manipulation
Margarie
Joined Jan 19, 2018
Hi guys can someone please help me with this expression:
(WX + Z’)(Y’ + Z) + W’(X+Y’)
I used the association property on the first operand and it leads me nowhere further from this initial expression.
This is what I did:
WXY' + WXZ + Z'Y' + Z'Z + W'(X+Y')
WXY' + WXZ + Z'Y' + W'(X+Y')
and now I can't seem to figure out what to do next. Any help is much aprecciated!
WBahn
Joined Mar 31, 2012
33,196
Yes I have. By using it I got the expression:
XW' + W'Y' +Y'Z' + XWZ + XWY'
Isn't that the same as in your first post once you distribute out the last term?
One subtle point on these kinds of question is what constitutes a "minimized" expression?
Is A(B+C) more "minimal" than AB+AC?
Margarie
Joined Jan 19, 2018
I think I have just simplified it.
I used the theorems:
1) A+A'.B = A+B
2) A.B+A'.C+BC = A.B+A'.C
And so these were the steps, if it may help someone:
X(W'+WZ)+Y'(W'+WX)+Y'Z' , using 1) with X(W'+WZ) assuming (A=W', A'=W, B=Z) and with Y'(W'+X) assuming (A=W', A'=W, B=X):
X(W'+Z)+Y'(W'+X)+Y'Z'
XW'+XZ+Y'W'+Y'X+Y'Z' , and using 2) with A=Z, A'=Z', B=X, C=Y':
XW'+Y'W'+XZ+Y'Z'
This was the simplest I got. Thank you guys and I hope it's correct, even tho I checked on logisim and it was equivalent. :p
Margarie
Joined Jan 19, 2018
To answer your question I'd say it depends on the proximity someone may have with the subject, even tho it is equivalent anyways! I guess it is probably about the perspective some people might have, because it doesn't make it more minimal, for me it's just the same :p
