how to simplify this boolean algebra expression with only boolean algebra
Maremare
Joined Sep 12, 2019
I have to show that Y and Z are equal,
Y = (~ABC) + (A~B~C) + (A~BC) + (AB~C) = (~ABC) + (A~C) + (A~B)
But I don't know how to simplify this
Z = (A+B+C) ( A+B+~C) (A+~B+C) (~A+B+C)
How do i start?
(with ~ i mean invert)
WBahn
Joined Mar 31, 2012
33,209
WBahn
Joined Mar 31, 2012
33,209
okey thanks!
but how can I do that if I the question is "Show with Boolean algebra that the two expressions are the same."
Consider if you are asked to show that the two expressions:
(x+3)(x-9)
and
(x-3)² - 36
are the same.
Could you not expand each to get
(x+3)(x-9) = x² + 3x - 9x - 27 = x² - 6x - 27
(x-3)² - 36 = x² - 6x + 9 - 36 = x² - 6x - 27
And since both expand to the same expression, conclude that the two original expressions are equivalent?
Also, keep in mind that once you get them both to the same intermediate expression, you can always walk the process backwards and use that to convert one expression into the other explicitly.
