Hi guys and girls
I am attempting to run two radios back to back and have run into an issue in order to PTT the radio I need a GPIO to go down to ground. So I need the one radio to key up when the other receives, so I have found a part of the circuit that gives a 3.3v when it receives so I proceeded to use an NPN transistor. The collector goes to ground emitter to the GPIO and base to the 3.3v on the other radio through a 1k resistor. Now this works and the radio keys up as I should. The problem I am facing is when the other radio stops receiving the 3.3v no longer disappears thus the transistor remains active.
More info
both radios run off the same supply
there is a 100k pull-down resistor on the receiving radio(3.3v to base)
there is a pull-up resistor on the GPIO so 3.3v is present
Any ideas what I am missing?
More info
