I'm working on a simple project and have run across a problem. Been a long time since I've done circuits and cant seem to get this problem solved.
I need a simple circuit that when a switch is flipped it will produce a spark over a 3mm gap. Does anyone have an idea on how to do this? I've tried creating a simple/modified marx generator to create the spark but still no luck.
Been using:
1 Mohm resistors
4kV 102 pF Capacitors
9V Battery
Thank you,
kevin
Been using:
1 Mohm resistors
9V Battery
Thank you,
kevin
